Just installed the 30day version of flowcode 8 tried to compile hex for Arm but i have an error of "arm compiler toolchain is not installed" is there a 3rd party compiler i need to install please.
Thanks.
Toolchain flowcode 8
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Toolchain flowcode 8
All of the toolchains are available on the Flowcode download page:
https://www.matrixtsl.com/flowcode/download/
We have separated them from the main install to reduce it's size.
- Been thanked: 1 time
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
What is your target processor?
Have you installed the correct ARM toolchain?
These are normally installed at "//Program Files (86)/Flowcode/Common/Compilers"
Could you check what you have there?
You've downloaded it but did you install it?I've down loaded the tool chain but still says not installed
The file is a.msi extension. It's sitted in my download files.
do I need to create a file in the flowcode folder and put it in there???
- Has thanked: 553 times
- Been thanked: 1081 times
You need to run the file. Msi files are installation packages.
― C.S. Lewis
― C.S. Lewis
Hi Alanj13100,
Just right click on it and select install or double click it.
Edit.. crossed post with kersing.
No, a msi file can be treated the same as .exeAlanj13100 wrote:do I need to create a file in the flowcode folder and put it in there???
