First bugs.
mnf
Has thanked: 70 times
Been thanked: 440 times
First bugs.
Post by mnf »
Sorry - someone had to be first....
1) When adding a macro - Tabbing through input fields never goes to the parameter fields (First up is Display name - then through macro selection - macro - return - Ok and edit (with a chime)) etc - is there a keyboard shortcut to select parameters? Moving between parameter fields seems a bit slow (on an i7) - there is a noticeable delay after clicking on a field.
2) I mentioned this with v7 - creating a loop with an unknown variable displays an empty dialog box.
(15.62 KiB) Downloaded 851 times
3) For some reason my install didn't find (or include) the AVR toolchain. I haven't had enough of a play - but probably a setting I can copy across from my v7 install?
Re: First bugs.
Hi Martin,
Points 1 and 2 are things we can certainly look into now we have the release out the way.
Point 3 has been answered by Steve on another thread.
All of the toolchains are available on the Flowcode download page:
https://www.matrixtsl.com/flowcode/download/
We have separated them from the main install to reduce it's size.
