Can't see all chip pins
markavo
Has thanked: 10 times
Been thanked: 2 times
Post by markavo »
maybe this is something i'm missing.
I do not see all the chip pins.
When i try to select a pin i see the bottom half of the chip
When i click view / chip i see the top half
i'm using ARM NUCLEO-144 F746ZG
Update checked flowcode 7 and it’s the same
But connected to 4K tv and I can see all the pins.
Is it not possible please to be able to scroll the box with the chip pins so I can run at a lower resolution on my laptop.
Re: Can't see all chip pins
I've checked and this seems to be working ok for me, so I suspect it is something to do with your PC's DPI settings. I'll pass this on to the development team to look at.
markavo
Post by markavo »
Thank you.
If i connect a second display (4k tv) and use as a second monitor drag the properties over to the second screen i see all the pins but not on the laptop with a resolution of 1366 x 768
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Are you using display scaling on the 1366x768?
https://youtu.be/NF210WeR9C8
markavo
Post by markavo »
Thank you, just tested but no luck no matter what setting i choose i still miss the top half of the ic when selecting the pins for the 32F746 i see from pin 9 downwards arduino mega is fine its square shaped when selecting the pins this one for some reason is shaped as a dil packaged ic but in reality its square.
Has thanked: 481 times
Been thanked: 699 times
The pinout of the Nucleo and Disco boards were intended to represent the pin header of the board, rather than the raw chip device.
I think for some extra pins were needed to support things like onboard display, so some inconsistency has crept in :roll:
If anyone has any particular chip requirement, let us know and we will add it to our pending list and endeavour to create an FCD descriptor for it
