I have just taken delivery of a new BL0032-1 dsPIC board.
The USB drivers have been downloaded and installed on a 64Bit windows 10 Machine...
The symptom is that the PC will not recognise the target USB port - therefore cannot program the board.
I have observed the following
- The PC will recognise the ghost port - PC beeps when you plug it in and the device is recognised within Windows.
- the board powers up when you plug into the target USB port and the test program operates i.e. port H/L strobe in sequential order – means the target processor is running
- Plugging in an external power supply does run the board however does not change the status i.e. the target port is not recognised.
I guess the question is – is the board faulty
All the best
Pete
