STM32F746 Discovery SD RAM
An area to discuss ARM specific problems and examples
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
I tested the graphics capabilities of the STM32F746 Disco.
It's amazingly fast if I load the image from RAM or ROM.
Unfortunately, RAM is small, only one image has enough 16bit R5G6B5 variable space.
I tried the SD card (old project GLCD_FAT (thanks Benj!)) Approx. It's capable of 200kB / s, this is a full screen shot of 2 seconds. When I load the image into RAM, it is quickly drawn.
I tried downloading the image to a ROM, but it's also very fast to display.
Unfortunately, RAM and ROM are finite in size, I remembered the SD RAM.
I see that Flowcode uses SD RAM for the screen and if I think of the camera interface (camera interface has no Flowcode component).
The point:
If so, can you give an example of using SD RAM? (Code C would also help)
If it was working, the complete GUI would fit on a memory card, and full load would be loaded into the SD RAM at power up. The program must address the memory vectors only.
If you're interested, I'll upload SD + RAM, ROMs.
Re: STM32F746 Discovery SD RAM
Sounds like you've been making good progress :D
I can send you the component source for the display if that would help things. STARM family is not my speciality so I'm not 100% up to speed on how everything's been done. I made the display component but from C code that was provided to me :wink: Leigh might be able to help you further.
If you think this is worth a go then let me know and I'll send you the component source via PM.
STibor
Post by STibor »
It would be great if you shared the source.
Thanks!
I'm thinking about programming RLE decoding, saving little memory.
Great little picture conversion program: http://www.riuson.com/lcd-image-converter/
I attach a ROM and SD Card + RAM framebuffer based 16bit image viewer.
GLCD_FAT_16bit_RAM.zip
(567.53 KiB) Downloaded 499 times
GLCD_FAT_BMP_16bit_bitrom_menu.zip
(300.77 KiB) Downloaded 391 times
Has thanked: 481 times
Been thanked: 699 times
I've not tried using the SDRAM of the Disco board, but this should be possible via the HAL, something like this ...
Add the HAL structures in the Supplementary Code
SDRAM_HandleTypeDef     SDRAM_Handle;
FMC_SDRAM_TimingTypeDef SDRAM_Timing;
Initialize the HAL in a C icon at the start of main
You will probably need to read up on the HAL interface to see if any of the structures need any initialized data settings
HAL_StatusTypeDef SDRAM_Status = HAL_SDRAM_Init(&SDRAM_Handle, &SDRAM_Timing);
Write or read from SDRAM using the HAL functions in a C icon
HAL_SDRAM_Read_8b(&SDRAM_Handle, SrcAddress, &DstBuffer, sizeof(DstBuffer));
Hope that helps and gets you started
Leigh
STibor
Post by STibor »
Thanks!
I try ...
