PROBLEM V8 CON USB
Foro para hablantes de español que deseen escribir en su lengua materna.
MOCUELSL
Has thanked: 8 times
Been thanked: 5 times
PROBLEM V8 CON USB
Post by MOCUELSL »
Good morning, Benj.
When compiling the program that I enclose in the Pic16fj1024gb610, it works well if the USB communication cable is connected to the test board, but if I disconnect the USB cable the program stops and it does not continue the rest of the code until I return to Connecting the USB cable does not work. Thank you.
PANTALLA TFT ILI9341 - USB.fcfx
(12.66 KiB) Downloaded 456 times
Re: PROBLEM V8 CON USB
I've replied to your post here: viewtopic.php?f=76&t=20198
