Hi Team.
Just checking with you before I invest to much time and give wrong advise to my customer,
At this moment we are using a MIAC for PIC very successfully with a labVIEW /USB slave interface on a Test Rig ,my customer are in the process of building a Test Rig for testing and validation of rebuild Brake components.We would like to have a bit more processor performance and looking at a dsPIC MIAC however my concern at this point is how much effort it would need to make the USB slave components and the MIAC USB Slave firmware work on the dsPIC MIAC.Is this possible ?
dsPIC MIAC and labVIEW-USB Slave
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: dsPIC MIAC and labVIEW-USB Slave
I've had a look at the MIAC Slave code and think that this should be transferable to the dsPIC MIAC without too many issue.
Looks like the USB Slave needs some work too.
I'll have a chat with Ben about that tomorrow and see how doable we think this is.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Leigh.
Thank you I appreciate ,
Would be great if you and Ben can come up with a solution for dsPIC and the USB stuff to interface to labVIEW
I will wait a for you to come back to me on this
Regards QMESAR
Regards QMESAR
- QMESAR
Hi Team,
Any results here
Have good time
Any results here
Have good time
Regards QMESAR
Regards QMESAR
- LeighM
We did have a chat about this and think it is doable, the problem is finding time to implement it,
staff holidays are impacting workload at the moment. Will keep you posted.
Leigh
Leigh
- LeighM
Ben fixed the USB Slave component yesterday and pushed it to the V8 auto-update.
So I've just tested my dsPIC MIAC Slave V8 conversion and it is working OK, not that I've tested everything.
Attached,
Leigh
Attached,
Leigh
- MIAC (dsPIC) USB Slave Source V8.fcfx
- (65.8 KiB) Downloaded 492 times
- QMESAR
Leigh and Ben
Thank you so much this is great ,I will have a go at it .
I appreciate your efforts .
Regards QMESAR
Regards QMESAR
