I have a big problem with flowcode7. Last month i realized a new program and I programming my card arduino mega and work perfectly.In this moment I open the same project and when I try programming card with flowcode7 this crashing, don't programming and automatically close flowcode
this same problem I have in other computer.All computer have a windows10
do you have an idea?
is it possible that it happened after a windows 10 upgrade?
best regards
FC7 crash and not program
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: FC7 crash and not program
What do you mean by "Crash"?
Do you get any error messages?
It could be Windows 10 anti-virus, see this post ...
http://www.flowcode.co.uk/mmforums/viewt ... der#p88564
Yes Ihave installed antivirus in my pc but the problem also exist when antivirus in desable mode
I installed the fc7 in other pc with different antivirus and the problem is same.
when I realized my program, flowcode work in simulation, compile and generate "hex" file., but when I "Press OK to continue" for insert program in my arduino mega card,after 5 second appear the windows message. (show the pdf file)
(sorry for my english)
- screenshot.pdf
- (174.3 KiB) Downloaded 490 times
- LeighM
Is the Arduino USB to virtual com port installed OK?
When you connect the Arduino board, Windows should allocate a COM port for it,
and should be visible in "Devices and Printers" settings.
This COM port (e.g. COM10) has to be entered on the Build->Project options screen of Flowcode
This thread might also be of help ...
http://www.flowcode.co.uk/mmforums/viewt ... 677#p88677
Hi LeighM
I tried running Windows in safe mode, but not program.
I tried replace "avrc_arduinoA.bat" in C:\Program Files (x86)\Flowcode 7\compilers, but not program
when I conect the arduino card show a driver (look pdf attacted). The same problem are with mega and nano arduino card.
I try reinstalling flowcode7? is it possible? , first remove old fc7 in my pc?
how many installations can I do without problems?
thanks
thanks
- com_port.pdf
- (65.07 KiB) Downloaded 497 times
- LeighM
This might help ...
http://www.flowcode.co.uk/mmforums/viewt ... 198#p85198
Hi LeighM
thankyou for your support.
I removed FC7 from my pc and reinstall version 7.3.0.5 and it work perfectly. Is this latest vrsion or exist a other version?
I don't understand because two different computer present same defect in same moment. This is principal computer I use every day but flowcode7 was 20 day not used. the other pc I use sometime but in the same moment present same defect have you an idea?
Best regards
Best regards
The latest v7.3 updates can be found here to bring you fully up to date.
viewtopic.php?f=63&t=19743
