Need some help understanding I2C process using FC components and Interrupts.
I will probably be using 2x Atmel328P based uC'ers.
It looks Like I will need to implement 3 or 4 byte communication occasionally between the two. I see no mention of interrupts or ISR's when I drag the component to the dash board or the component icon to the tree.
So how do I implement a 'transparent; comms system utilising the onbaord hardware I2C port
thanks
Matt
Inter uC Comms - I2C
- Has thanked: 70 times
- Been thanked: 440 times
Re: Inter uC Comms - I2C
I managed to get an Arduino to communicate successfully with two (or more) slave boards (all 328p)
See http://www.matrixtsl.com/mmforums/viewt ... 71&t=20043
My ultimate goal was to create a circular communications system with each slave passing the (altered) message to the next slave before it was ultimately passed back to the original master - you can see my (non-working) effort in the same topic. I've had little time to work on it because of other commitments - but will come back to it at some point and hopefully progress a little further.
Unfortunately the Flowcode doesn't utilise the interrupt facility of the AVR hardware (and I guess this would be very difficult to do in whilst supporting multiple targets)
Hope this helps a little - what are you trying to achieve?
Hi Martin,
This seems a massive omission for a comms based system.
Matt
Sorry - this is going to sound really rude - How do you know I2C Interrupts are not supported. - hands on experience or from Matrix?mnf wrote:Unfortunately the Flowcode doesn't utilise the interrupt facility of the AVR hardware (and I guess this would be very difficult to do in whilst supporting multiple targets)
Matt
Partly from use and partly because I thought I'd read it in the forums:
For example viewtopic.php?f=7&t=19166&p=84617&hilit ... upt#p84617
But that was back in October and FC7 - now there's the whole new world of FC8.
- and I'd love to be proved wrong; an interrupt based system would make for some neater code!
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
I've done a quick edit to the ATMEGA328P fcd (Flowcode V8) to add a TWI interrupt option.
It's experimental as I have not had chance to test it, but if you want to give it a go, attached
- ATMEGA328P.fcdx
- (20.91 KiB) Downloaded 208 times
Hi Leigh,
Can I use that with FC7?
Also, I notice in the 'Latest' FC7 than Ben posted that there has been some work generally on the ATMEL328P does this included work on the trigger levels of the Pin Change interrupts (triggering on both rising and falling edges)
Matt
Matt
- LeighM
At a quick glance, it looks like itAlso, I notice in the 'Latest' FC7 than Ben posted that there has been some work generally on the ATMEL328P does this included work on the trigger levels of the Pin Change interrupts (triggering on both rising and falling edges)
V7 version attachedCan I use that with FC7?
- ATMEGA328P.fcdx
- (20.25 KiB) Downloaded 206 times
