Missing pic8 compiler file
I have just installed Flowcode 8 and wrote a simple program to try out the new features and get familiar with it. However when I tried to compile to chip I got the message
"ERROR: Can not launch process: The system cannot find the file specified".
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code -1
I have looked in the above batch folder and have attached a screenshot of the file present for your perusal
Could you please assist
- 2018-07-17_15h04_14.jpg (39.53 KiB) Viewed 19038 times
Re: Missing pic8 compiler file
Hi kramtlas,
All the compiler tool chains are separate downloads to reduce overall Flowcode download size.
Have you tried looking in the Flowcode download section?
Yes, I downloaded the 8 bit Pic toolchain from the Flowcode download section
After installing compile it will place a pic folder in:
C:\Program Files (x86)\Flowcode\Common\Compilers\ <64 bit windows
Or
C:\Program Files\Flowcode\Common\Compilers\ <32 bit windows
If the pic directory is missing then you could try installing:again.
Make sure you have downloaded correct compiler.
Out of curiosity what folder have you got within ...\Flowcode\Common\Compilers\?
You could of downloaded and installed 16bit PIC by mistake?
Or
Hi kramtlas,
Just catching up.
Did you get your issue resolved?
Just catching up.
Hi medelec,
No I didn't unfortunately, as you can see from my first post attachment the file seems to be present in the correct location. Although when I try to compile to chip en error message states " PIC compiler toolchain not installed " I have attached a screen shot of the message displayed.
- 2018-07-25_16h54_41.jpg (12.36 KiB) Viewed 18967 times
Hi kramtlas,
Sorry for the problems you're experiencing. The error in your first post seems to indicate that Flowcode knows the location of the compiler, but is having an issue launching it. The error in your latest post suggests that Flowcode now does not even know the location of the compiler. So this situation is somewhat unusual in that a completely different error has manifested itself.
Could you check the following for me?
1) Open your start menu and type "regedit" (without the quotes) and press Enter. This will open the windows registry editor.
2) In the registry editor, paste in the address bar at the top "Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\MatrixTSL\Flowcode\Common" (without the quotes) and press Enter.
3) Check that there is an entry titled "Compiler_pic" in the "Name" column, with "REG_SZ" in the "Type" column, and then "C:\Program Files (x86)\Flowcode\Common\Compilers\pic" in the "Data" column.
If this entry is missing, then something has altered your registry since your first post. This could perhaps be antivirus software, or a system restore utility. (It could also explain why Flowcode was having issues launching the compiler initially).
Best regards,
Daniel
Best regards,
Daniel
Hi DanielM,
I checked the compiler location in the windows registry editor and it was different i.e. it did not contain the "common" folder, so I copied the "pic" folder into the "compilers" folder as per the entry in the registry editor. This still do not work and the error message stated that the system could not find the file specified.
Again I have attached some screen shots
kramtlas
kramtlas
- 2018-07-26_13h46_48.jpg (26.84 KiB) Viewed 18902 times
- 2018-07-26_13h47_13.jpg (32.69 KiB) Viewed 18902 times
- 2018-07-26_13h51_04.jpg (53 KiB) Viewed 18902 times
Hi kramtlas,
My sincerest apologies for the delay with this response.
The issue has me at a loss, due to the fact that the errors do not seem consistent. (The first suggested that Flowcode could access the correct registry entry, but the second suggested the opposite!) The fact that it is clear that the file is in the correct location but cannot be seen by Flowcode, and moreover that the registry entries were not consistent with the true path of the compiler, suggests some form of interference by an external source (such as aggressive antivirus or system maintenance software..?)
Did you have any failed attempts at installation at any point? Are you using registry management software?
My suggestion is the following:
1) Reboot your PC into safe mode (if you are using Win 10, then the instructions are here https://support.microsoft.com/en-gb/hel ... -safe-mode ), and stay in safe mode for steps 2 and 3 below.
2) Check and make sure that the registry entry from the last post definitely matches up with the location of the compiler on your hard disk.
3) Attempt to compile using version 8
If this does not work, uninstall V8 and the PIC toolchain. Then reinstall V8 and the PIC toolchain, but do not launch V8. Restart your PC into safe mode and follow the above steps again.
Daniel
Daniel
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
Hi Daniel,
I had the same issue on the weekend...
I started out with V8 and pic16 toolchain, running since fc8 release with no problem...
On the weekend I purchased pic8 toolchain and added licence...got the same result as previous post error1 file not found etc...
Tried all of the suggested fixes with no luck....had to unload fc8 and reload fc8 and both toolchains. Problem sorted itself out after reload.
Problem started after pic8 toolchain was loaded sometime after the initial fc8 install, some 2 months.
Best
Pete
Best
Pete
sorry about that Chief!
Hi Pete,
Thanks for the post, I have tried what you suggested might be the problem but unfortunately this fix has not worked on my computer. I will just have to keep plugging away until I find a solution.
Best Regards
Kramtlas
Best Regards
Kramtlas
Hi Kramtlas,
I'm still trying to replicate this issue to prevent this being a problem in future. Are you still experiencing this issue?
Would you be able to answer the following for me to help me diagnose?
What were the results of the sequence of steps in my previous post (prior to reinstallation)? Did you receive the error from your first post ("ERROR: Can not launch process"), or the one from your later post ("toolchain not installed")? After reinstalling and following the steps, was the error the same?
In both iterations (doing the steps prior to reinstallation, and then doing the steps again following reinstallation), were the registry entries consistent with the state of the filesystem (in step 2)?
Daniel
Daniel
Hi Daniel,
I managed to sort the problem out. The default settings for the compiler seemed to be the issue, I looked through the help menu for compiler settings which were different to what the Flowcode 8 settings were preset to. I altered them to the settings in the help file with the omission of the end part which is highlighted in red and the compiler now works. I have attached files to show the changes made and the last file shows the compiler working although there are a few issues which I have made notes on which I would be grateful for some assistance with.
I will send a second post as I can't seem to add more than three attachments.
Kramtlas
Kramtlas
- 2018-09-03_15h47_04.jpg (124.57 KiB) Viewed 18657 times
- 2018-09-03_15h25_53.jpg (44.74 KiB) Viewed 18657 times
- 2018-09-03_14h22_34.jpg (42.29 KiB) Viewed 18657 times
Additional files
- 2018-09-25_14h05_49.jpg (63.09 KiB) Viewed 18655 times
- 2018-09-03_16h13_49.jpg (76 KiB) Viewed 18655 times
- 2018-09-03_15h54_02.jpg (42.73 KiB) Viewed 18655 times
Yes thanks, I appreciate your assistance. I finally got the compiler working and have sent a post but basically it was the default settings that were preset with the Flowcode 8. There a few faults reported which I have asked for some assistance with but at least it works now.medelec35 wrote:Hi kramtlas,
Just catching up.
Question. Do you know how to set the ref (-) and ref (+) for either the ECIO 40 or 16F88 Pics? I was looking for some example codes but am struggling to find any that explain how to do it.
Kramtlas
Glad you have got the compiler working now.
Currently, the only choice within ADC component properties is for Ref to be between +Supply and GND, FVR and GND (If supported by device) or VRef pin and GND.
Any other options will require a small bit of C code change within relevant CAL_ADC.c file.
I was looking to use the Vref pin (+) and Vref pin (-) to allow me to use the full adc resolution between say Vref(+) @ 3V and the Vref (-) @ 2V. I was hoping to get some example code for me to learn from as I have not used this feature before.
kramtlas
kramtlas
Vref- is not an option, unless C code is used as stated in a previous post.
You can only use Vref+
To select VRef plus, add an ADC component to 2D or 3D panel from the Inputs component list e.g Potentiometer(Colour).
Select the Pot that's on the panel, then right click and select properties.
Change the Vref voltage to 300 if Vref+ is 3V.
Also, change Vref option from VDD to VRef+ Pin
So now when the ADC input is at 3V the value should be 1023 for 10 bit int or 255 for 8bit byte.
As for the code to use VRef-, that means changing ADC Cal file.
When I get a chance I will post on how to modify ADC cal, but it's at your risk.
At least with give you a basic idea.
If you create a flowchart and make the above changes and does not do what you want it to do on hardware,
then we can look at your flowchart for you.
Just select Attachments tab, Add files then upload Flowchart in this thread.
To enable both Vref+ & Vref-
Taking 16F88 as an example.
Open 16F88.fcdx which is found within C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC
Make a note of
Open that's loacated within C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC
Search for which is the 2 that's within .fcdx file
You will see:
Look at the 16F88 Data sheet you will see:
So for VRef+ & Vref- both & have to be set.
You will need to edit
change to:
Important:
You must include both braces {}!
Save
If Flowchart is open use the reload option.
Make a note of
adc type='2'Code: Select all
PIC_CAL_ADC.cSearch for
MX_ADC_TYPE_2You will see:
#ifdef MX_ADC_TYPE_2
void FC_CAL_ADC_Enable (MX_UINT8 Channel, MX_UINT8 Conv_Speed, MX_UINT8 Vref, MX_UINT8 T_Charge)
if (Vref == 1) //assign VREF functionality
st_bit(ADCON1, VCFG1);So for VRef+ & Vref- both
VCFG0Code: Select all
VCFG1You will need to edit
PIC_CAL_ADC.cchange to:
if (Vref == 1)
{ //assign VREF functionality
st_bit(ADCON1, VCFG0);
}Important:
Save
PIC_CAL_ADC.cIf Flowchart is open use the reload option.
Hi kramtlas,
I'm glad that you have your compiler issue resolved.
Just to confirm, the image of your compiler settings with "$(appdir)" is now what you have it set to, and your compilers are now located in "C:\Program Files (x86)\Flowcode v8\compilers"? Did you move these yourself? Because it seems at odds with the location given in your previous posts. Did you move the location on your hard disk in order to be consistent with the settings you received from the wiki? I am trying to establish whether there is a problem with paths/registry, or if the issue was in fact just the trailing arguments to the batch file.
Regarding the messages you receive in the compiler window: This is due to Flowcode's usage of the standard version of Microchip's XC8 compiler. It is possible to purchase the PRO license for XC8 yourself, and use it with Flowcode, but as far as I know you can only purchase the license with a monthly subscription. For most people, the benefits of the PRO compiler are not worth the cost. You can find more info here https://www.microchip.com/developmentto ... 006021-sub
Daniel
Daniel
Hi Daniel,DanielM wrote:but as far as I know you can only purchase the license with a monthly subscription
You can also have the professional version (SW006021-2H) for a yearly fee of about £150+ vat if you want to keep it up-to-date as that is for updates and support only, not for a licence.
But to do that you must purchase the professional licence first for a one-off charge of £762.47 + Vat
After paying £762.47 + Vat it stays professional for life, you just won't be able to use on compiler updates that come out a year or later.
The compiler version will have to stay at the last update before the year ran out.
- CamargoF
- Has thanked: 6 times
- Been thanked: 7 times
I got the same PIC missing compiler after I upgrade the Flowcode few days ago.
It looks like there is an error on Matrix batch installation file. Please, check it and release a fix.
It is amazing that after almost 1 year the first issue it still happening.
I download and used the REPAIR option of the PIC toolchain and it does not help to fix the problem.
By the way, only the ARM toolchain does not have the common folder.
I was able to fix the problem copying the C:\Program Files (x86)\Flowcode\Common\Compilers\pic to C:\Program Files (x86)\Flowcode\Compilers\pic.
