MPU9250 9-axis sensors
Has thanked: 182 times
Been thanked: 179 times
The Component MPU9250 is comfortabel to use with FC8.
The small problem is that I have to select I2C channel nr 5, every time I load my program to FC8.
That gives no error. But the program in the PIC will then hang on the part of the sensor.
where does the problem come from? From the Component or PIC32mz definition?
Re: MPU9250 9-axis sensors
This should not be the case and so it sounds like a bug.
Let me try and replicate for you.
Replicated and fixed, new component should now be available via the update system.
Thanks for letting us know.
Very good. It's fine now. Thank you
I made the update to FC8.1
Now the problem is back
For the FC8.1 i have to remove 8.0 and install 8.1
That should not matter.
Hmm that's odd it's still working fine for me using 8.1. The update system currently seems to be disabled for 8.1 so I'll see if we can get it back online so we can check which version of the component you have installed.
The patch is not working on a win7 computer and on a win10 computer
But I am not sure that there is the right version. Various problems are back. These were ok before.
-The uart from the Pic32 is wrong (again)
-The mpu9250 is wrong (again)
-Grove Display I'm not shure what happen...
But scada is very good to have...
It's ok again. I received the few updates today.
