Can any one help please. trying to connect the above to a BL0080 with a 16F18877 PIC. Using the Grove sensor board. I am using ports A & B for the combi board and plugging the sensor board into port C. The problem is that I can't figure out which pins to connect the SCL & SDA to. My first choice were port C pins 3 & 4 but tried these using software, channel 1 and channel 2. Still won't work.
Got it working in simulation but that is with the GUI
Gary
Grove SHT31 Temp & Humidity Sensor
Re: Grove SHT31 Temp & Humidity Sensor
Hi Gary,
It depends on which port on the Grove board you connected the sensor to. Each socket should be marked with two numbers e.g. 0&1 or 2&3. The SDA pin connects to the odd pin and the SCL to the even pin. e.g. SCL = C2 / SDA = C3.
We have recently found a problem with this component which has now been fixed. Use the Help -> Check for updates system to get the latest version of the component.
Let us know how you get on.
