help using sleep mode
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Post by CSM2711 »
I moment I try to use the sleep mode of the PIC16F18313, unfortunately I have the following problem:
the Sleep mode works fine until I activate the Timer0.
Unfortunately I do not understand why sleep mode does not work when Timer0 is enabled.
Does anyone have an idea?
Thank you in advance.
90_work_sleep.fcfx
(11.66 KiB) Downloaded 185 times
CSM2711
Has thanked: 1 time
Re: help using sleep mode
Post by CSM2711 »
ok i found the mistake.
You mus set syncronisation to "not synchronised"
