Max7219 new component!
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi all!
Martin "mnf" Valued contributor has been kind to create a Macro component for me, a macro component for the Max7219 display. 8x8 dot display.
With the permission of Martin, (thank´s Martin) I hereby share it with everyone here, and demonstrate some of all the fancy function the display can do. and it is many :D
First you need to place the Max7219_v2.fcpx component in a lib and add the component to FC8.
Next, you have to create a path in Flowcode8 Wiev > global option > location (for me: C:\Flowcode8\Max7219_v2.fcpx;).
In my case/example I use an Arduino Nano 328 as device. I am sure that other device´s also can be used. And you need a display like this: https://www.ebay.com/itm/MAX7219-Microc ... 1438.l2649
I made an example with some of the funtion which is possible with the Component macro, there is many fancy function.
If you have, like me a little passions for display´s, I recommend to give it a try :lol:
Best regard and happy newyear!
Jorgen
MartinMax7219Test.fcfx
(22.73 KiB) Downloaded 735 times
Max7219_v2.fcpx
(8.38 KiB) Downloaded 714 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Max7219 new component!
Post by mnf »
Thanks Jorgen,
Runs smoothly for me :D Good to see someone using the component :!:
Post by jgu1 »
Hi Martin!
Of course when you have done such a great job, it must also be used, and it Will. :D Good component. Thank` again.
Br Jorgen.
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I can't seem to import this component.
FC always opens with the message that this component is made in a newer version of FC.
I have the latest FC V8 and no updates available.
Any help is welcome.
If this component runs smooth, why don't distribute as a standard component with the coming update of FC8?
mnf
Post by mnf »
Compiled with V8. There are also versions made with v7 on the board, see the final messages in viewtopic.php?f=66&t=19356&hilit=Max7219 for example. Unfortunately I'm rather under the weather at the moment, and looking at a computer screen for more than a few minutes at a time is out :cry: - so I can't recompile at present. If you pm me I can post you the source code (when my head stops banging)
I'd be quite happy if Matrix want to distribute it as a component, although they would probably want to add some simulation code ..
MJU
Post by MJU »
Thank you mnf,
Sorry to hear you are ill, hope you get better soon!
But there seems something wrong with the way I add components to my Flowcode V8.
The description above doesn't seem to work for me?
What is the most recent Flowcode 8 component for these modules? Is there one that also has support for 7segments?
Pactor
Has thanked: 20 times
Been thanked: 14 times
Post by Pactor »
What a lovely component, you could learn so much by seeing how it was put together.
I'm having great fun with it.
Thank very much.
Monaga
Post by Monaga »
Dear Mr.
I have the FC V6 version, could you support me to generate the component for version 6
thanks for your help
