I2C error
linktech
I2C error
Post by linktech »
hi ,I have problem with i2c with my project using LCD Display 2x16 in Arduino mega 2560 R3 once I compile is have error code in below the details.
I was read this in the forum and update my software version but is still same problem I cant fix it.need help guys
Has thanked: 514 times
Been thanked: 465 times
Contact: Contact dazz
Re: i2c LCD problem
Report this post
Quote
Postby dazz » Thu May 24, 2018 10:18 pm
i just did the update on my pc from this link
https://www.flowcode.co.uk/temp/FC7_Late ... -05-18.zip
follow Martins post to move the files,and it will work
Rgards
Dazz
Thank You
PDF File error FC7.pdf
(617.14 KiB) Downloaded 232 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: I2C error
Post by kersing »
Next time please post the errors in text form in your message, not in an PDF document. The errors can be found in a file .txt in the directory where your flowchart is saved.
Screen shots can be added to the forum message as well, no need to use PDF for this either. Just upload a jpg/png and add it inline.
― C.S. Lewis
Re: I2C error
You have not posted a flowchart either.
We can't help until you upload a flowchart that's causing these issues.
Is there a reason to run FlowcodeV7-3-0-5.exe instead of FlowcodeV7.exe?
Re-installing would be a start, but make sure anti-virus e.g Windows defender and firewalls are temp disabled as they could potentially interfere with installation.
