I try to connect FC8 with the ICD4 of microchip. One of the problems is that the device ID is lost when I program the pic with FC8. Afterwards, the ICD4 no longer connects to "Target"
viewtopic.php?f=78&t=20724
FC8 ICD4 MPLABX-v5.10 read device problem
- Has thanked: 182 times
- Been thanked: 179 times
Re: FC8 ICD4 MPLABX-v5.10 read device problem
Hi Stefan,
The ID words shouldn't be writable so maybe you're just setting a code protect bit in your configuration settings which is stopping them being read back?
Without a project for reference I'm just guessing.
The ICD4 and FC8 is working nice and very fast.....
With a little detour. There is an error because of the ID (serienumber). After this, the ICD4 deletes everything and it flashes the chip complet new.
I used this parameters in FC8:
Powered externally
C:\Program Files (x86)\Microchip\MPLABX\v5.10\mplab_platform\mplab_ipe\ipecmd.ex
Parameters:
/P$(chip) /F"$(outdir)$(target).hex" /TPICD4 /M /OL
from here is the errormessage(more a warning)
Connecting to MPLAB ICD 4...
Currently loaded versions:
Application version............01.05.12
Boot version...................01.00.00
FPGA version...................01.00.00
Script version.................00.02.65
Script build number............69cc1f643c
Target voltage detected
Target device PIC32MZ2048ECG100 found.
Device Revision Id = 0xA5
Reception on endpoint 129 failed (err = -10121)
Unable to read the device serial number.
A communication error with the debug tool has occurred. The tool will attempt to recover momentarily.
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x1d000000, end address = 0x1d0167ff
configuration memory
boot config memory
Programming/Verify complete
ICD4 Program Report
21-Jan-2019, 14:27:30
Device Type:PIC32MZ2048ECG100
Program Succeeded.
Operation Succeeded
FINISHED
Powered externally
Parameters:
Erasing...
boot config memory
ICD4 Program Report
Program Succeeded.
Operation Succeeded
FINISHED
If I use the Mplab x ipe to erase the PIC, it's working nice to flash to chip and it's faster
It's compile an flash in 18 Sec. The second time need 27 Sec. That's not a big problem.
The biger problem is to read the Device ID with the FC8. Is this possible to do with FC8?
Info read device id for PIC
https://www.mouser.com/ds/2/268/60001191D-752781.pdf
Memory locations 0x1FC54020 and 0x1FC54024 contain a unique device serial number (see Section 34.0 “Special Features”).
Message:
----------------------------------------------------------------------- first time after erase
Target device PIC32MZ2048EFG100 found.
Device Revision Id = 0xA1
Serial Number:
Num0 = 397799f4
Num1 = 25bfd880
----------------------------------------------------------------------- second time after erase
Message:
Serial Number:
Num0 = 397799f4
Num1 = 25bfd880
Hello Stefan,
Maybe try a newer version of MPLABX IPE if there is one available or let Microchip know of the problem and they may be able to fix it in the next release.
I'm afraid that during the programming stage we are in the hands of the Microchip IPE software e.g. there is nothing the Flowcode team can do to fix this problem.The biger problem is to read the Device ID with the FC8. Is this possible to do with FC8?
The ipe is very new.....
What I like to do is that my recorder's send a unic ID to the computer and save to the sd-card. I don't need to change the flashing part.
So I just thought of sending and saving the device id. Then all recorders have the same software.
