Automatic close flowcode 8
anugani12
Been thanked: 3 times
Post by anugani12 »
i have try to open flowcode v8 but automatically close.
uninstall and install again but same situation iam facing.
please resolve my issue.
Re: Automatic close flowcode 8
Has it worked previously or is this the first time you've used it on that PC.
Did you have another monitor connected at some point? Could the Flowcode window still be there but now appearing off screen or is the app also disappearing from the task bar?
anugani12
Post by anugani12 »
“Has it worked previously or is this the first time you've used it on that PC.”
Yes.
Problem From last 4 days
“Did you have another monitor connected at some point? Could the Flowcode window still be there but now appearing off screen or is the app also disappearing from the task bar?”
System display running flowcode v8 application only close immediately when open the application. Close in task bar also
V7 working fine.
anugani12
Post by anugani12 »
Bug video link.
please watch the you tube video sir.
https://youtu.be/jF6mSauYkUE
DanielM
Has thanked: 11 times
Been thanked: 22 times
Post by DanielM »
This is an unusual problem. Normally we would expect some kind of error. We will reset your settings to default in order to rule out some sort of configuration setting causing the issue.
Please try the following:
1) Click on your start menu and type "regedit.exe" to open Windows Registry Editor. (Please be extreemly careful using Regedit as you can easily damage your Windows installation.)
2) Then navigate, using the left-hand pane, to HKEY_CURRENT_USER\SOFTWARE\MatrixTSL,
3) Delete the key in the left-hand pane named "FlowcodeV8" (when asked if you wish to delete this key and all subkeys, click YES).
4) Close Regedit
5) Using Windows Explorer, navigate to "C:\ProgramData\MatrixTSL" (this folder may be hidden, and you will have to type it into the address bar in Windows Exploer), and delete the folder "FlowcodeV8".
This should reset all of the settings in Flowcode V8 to the default, the same as when the software was first installed, and should rule out any setting in Flowcode causing this problem.
Daniel
