calculation only on simulation
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Post by CSM2711 »
i try to create a component for using the internal temperature indicator.
So i add a scale from -40 to 85. Inspilulation the value schoeld be multiplied with 22 but only in the simulation....
I try to realize this bay use the simultion Symbol but it wont work... The value in the application (on the µC) will also multiplied with 22.
Can somebody help me ????
temperature.fcfx
(10.5 KiB) Downloaded 371 times
Re: calculation only on simulation
Try this instead.
temperature.fcfx
(10.52 KiB) Downloaded 418 times
I override the simulation macro for the exported component using the interface manager.
(10.18 KiB) Downloaded 1756 times
CSM2711
Has thanked: 1 time
Post by CSM2711 »
Many Thanks !!!!
This might also be of use to you in future.
viewtopic.php?f=77&t=20958
