I see a small red cross on a variable (uint in this case) both in the variables list as well as in the component macro it uses. What does that signify, is it an alert or error? (FC 7).
See attached screen shot.
Jan Didden
Small red cross on a variable - what does it mean?
- Flowcode v5 User
- Has thanked: 19 times
- Been thanked: 16 times
- (16.8 KiB) Downloaded 1227 times
Re: Small red cross on a variable - what does it mean?
Hi Jan,
The + means that the numbers will always be positive, so they are Unsigned.
If not got the + then they can go negative as they are signed.
So nothing to worry about as the + allows you to instantly tell if unsigned or signed.
