CircularBuffer does not appear on the 2D panel
- Noicon.jpg (44.72 KiB) Viewed 3350 times
Re: CircularBuffer does not appear on the 2D panel
Thanks for reporting, I have replicated the issue and we are investigating.
If you drag the component from the components toolbar to the 2D panel then it should work correctly. The 3D panel also works correctly.
Hi Benj!
Yes it is! But I do not work with 3D panel.
Thank you!!!
Thank you!!!
We have now fixed the problem but this won't get rolled out until we release a new executable. This will likely be around April when we are planning to launch an 8.2 update release.
For now please use the drag on workaround to overcome the problem.
