I2C 18F47K40
I2C 18F47K40
Software I2C is working as expected.
With channel 1 or channel 2 I2C does not work & no commands after I2C are executed.
The microcontroller is brought to a halt.
I2C test.fcfx
(122.38 KiB) Downloaded 334 times
Re: I2C 18F47K40
Hi Martin,
Leigh's got one of these device on order so we can investigate for you.
Re: I2C 18F47K40
Thanks Ben & Leigh.
When you test the device, can you also test ADC with internal OSC at 64MHz please as it appears to be wandering all over the place.
Thank you.
Has thanked: 481 times
Been thanked: 699 times
Re: I2C 18F47K40
Hi Martin,
I think I have the I2C fixed now.
Please try the attached updated CAL file. (C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC)
Leigh
PIC_CAL_I2C.c
(28.25 KiB) Downloaded 359 times
Re: I2C 18F47K40
Hi Martin,
I've just done a quick ADC test with default settings and it looks OK.
Do you want to post an example?
Leigh
Re: I2C 18F47K40
LeighM wrote:'ve just done a quick ADC test with default settings and it looks OK.
Hi Leigh,
Was that running the chip with internal osc @ 64 MHz?
Re: I2C 18F47K40
Just checked and that was running with OSCFRQ = 0x07;
as your previous program, so that will be 48MHz, not 64
Edit: Yes you are correct, it's a mess at 64MHz
Although in the datasheet there is note reference (3) against that setting, cannot find the relevant note though!
Edit 2: Just changed the ADC conversion speed to Fosc/16 and all is well again. (@64MHz)
Re: I2C 18F47K40
LeighM wrote:Just checked and that was running with OSCFRQ = 0x07;
Yes I was running osc for I2C at 48MHz.
What to change it to 64MHz when ADC was working.
LeighM wrote:Just changed the ADC conversion speed to Fosc/16 and all is well again. (@64MHz)
Brilliant thanks Leigh for your help on both I2C and ADC.
Will do some testing and let you know how I got on.
Re: I2C 18F47K40
Re: I2C 18F47K40
Hi Leigh,
Tried I2C with:
channel2 (SDA = RD0, SCL = RD1) - Working.
channel1 (SDA = RC0, SCL = RC1) - Not Working.
Software (SDA = RC0, SCL = RC1) - Working.
Using internal osc @ 48MHz
Re: I2C 18F47K40
Thanks Martin,
Interesting, I used channel 1 and port C OK, but not pins 0 and 1
One thing I did add in code at start of program was a setting of the port to open drain.
ODCONC = 0xff;
I then forgot to remove it to see if it was really needed.
I'm out of the office at the moment so will investigate further tomorrow.
Leigh
Re: I2C 18F47K40
Hi Martin,
Update: It does not require setting of the port to open drain.
But, weirdly, I can get it to work OK on every pin on port C except 0 and 1!
Hmm, does it need further investigation or a read of the silicon errata :roll:
I'll be back
Re: I2C 18F47K40
I suspect this might be something to do with the secondary oscillator
but haven't got my head round all the relevant datasheet sections yet
Re: I2C 18F47K40
I've poked my head into the datasheet but I've not spotted anything useful so far.
patrick schoon
Has thanked: 7 times
Been thanked: 13 times
Re: I2C 18F47K40
Post by patrick schoon »
Hi Guys,
I experiance the same problem with a PIC16F15356.
Software I2C is working but Ch1 and Ch2 are not.
FC8.1.1.11
PS
