LINAK ACTUATOR LA37 can now only run in or out
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hi every one
Problem with my solar tracker
Uses ECIO40P for tracker control
LINAK ACTUATOR LA37 can now only run in or out.
But Hall A and B no longer work :evil:
So why do I want to change the codes a bit?
Want a driving range at minim Down> 40) AND Up> 50 Max
A certainty that the tracker works in this area
But do you have a suggestion for changing the codes pictured below?
Please see Macro OpDown!
Attached coder:
SolarTrackerECIO40P-02-04-2019.fcfx
(281.1 KiB) Downloaded 203 times
Best Regard
Monie
Re: LINAK ACTUATOR LA37 can now only run in or out
Hi Monie,
Sorry I'm not quite with you, can you explain the problem you're having and where you think the issue is?
Monie Jacobsen
Hi Benj
Just found out that LINAK AKTUATOR LA37 is defective :( .
The spindle motor works ;-)
But the signals from LINAK ACTUATOR Hall A and Hall B no longer works!
Good working day for you.
Best Regard
Monie
