P16F1615 RX Interrupt PPS wrong
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Ben /Leigh.
I am using a PIC16F1615 UART the PPS settings from the component properties does not work the RX pin never get alocated to the pin you select
I have for now just add the below code after the UART Init Call and it is working fine now .
I have see similar issues on other P16F1xx devices however I did not investigate it as I was not underpressure to so now I need it :D
This code corrects the error
Have great time
Re: P16F1615 RX Interrupt PPS wrong
Hi Peter,
Thanks for letting us know. I have now pushed out an update which should solve the problem for you.
QMESAR
Post by QMESAR »
Hi Ben.
Thanks a million I will give it ago :D
