P16F1615 RX Interrupt PPS wrong
Posted: Tue Apr 30, 2019 9:24 am
Hi Ben /Leigh.
I am using a PIC16F1615 UART the PPS settings from the component properties does not work the RX pin never get alocated to the pin you select
I have for now just add the below code after the UART Init Call and it is working fine now .
I have see similar issues on other P16F1xx devices however I did not investigate it as I was not underpressure to so now I need it
This code corrects the error
Have great time
Have great time
