PEEK function on UART serial buffer
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
Hi is it possible in FC8 to PEEK (look at without removing) the first byte on a UART buffer? This woud be really helpful in synchronising actions a serial data stream.
Chris :D
Re: PEEK function on UART serial buffer
Hi Chris,
I'm afraid on the hardware if you read the buffer then the value is removed. A circular buffer combined with a UART RX Interrupt would allow you to read the data as and when you're ready and allow you to peek at the data.
