FC8.2 PIC18LF67K40 I2C brocken
streammaster
Has thanked: 7 times
Been thanked: 13 times
Post by streammaster »
Hi Ben,
I discovered that the I2C is not working when compiled to the target hardware. The compiler is MPLAB XC8 Pro. As soon as any of the cal macro control are issued to the bus the main loop will hang.
I'm using the I2c code using CAL which works successfully with some other FC8 project and processor.
I also tried to use the component (LIS3LV) and the effect is the same (it hangs without doing anything on the bus). I believe something is wrong with the PIC configuration.
The logic analyser shows no activity on the physical I2C bus so it looks that actual PIC hardware is not properly initialised.
I hope it is not a big issue for you to fix this as it is stopping me to continue to work.
I'm running on 18LF67K40 internal 64MHz clock and so far ADC and UART are working with this PIC and FC8.2 ok.
Igor
Re: FC8.2 PIC18LF67K40 I2C brocken
Hi Igor,
Can you post a demo program that shows the lock up so we can investigate. Can you also confirm if the lock up is resolved if you switch to a software I2C channel.
streammaster
Hi Ben,
Thank you for your reply. Yes, if I use the software I2C then it is working correctly.
(328.71 KiB) Downloaded 1116 times
However, if I use Channel1 the i2C bus SDA and SCL stays high and no activity. The loop hangs at trying to execute first Cal command in "i2c_Read_sensors" macro (initialise is actually passing).
I attached my test program as you requested. Currently, the i2c is set to software emulation which is only working on the target.
The Accelerometer is the slave device which I'm talking to. It is LIS3DH Accelerometer. I'm accessing the "Who I Am" register (0x0F) and device address is 0x18. I'm reading a single byte and I'm getting the expected value "51" (0x33). The demo FC project is attached.
Igor
PIC18LF67K40 basic config I2c only test.fcfx
(27.48 KiB) Downloaded 304 times
streammaster
Hi Ben,
do you have any ETA on fixing this bug?
Igor
Hi Igor,
Many thanks for chasing this one up. I have looked in the definition file and the chip was missing the remappable I2C support required by the hardware pins. This has now been added and pushed to the v8 update system so hopefully will now work correctly.
Let me know how you get on.
