FC8.2 PIC18LF67K40 I2C brocken
Posted: Wed Jun 19, 2019 3:00 am
I discovered that the I2C is not working when compiled to the target hardware. The compiler is MPLAB XC8 Pro. As soon as any of the cal macro control are issued to the bus the main loop will hang.
I'm using the I2c code using CAL which works successfully with some other FC8 project and processor.
I also tried to use the component (LIS3LV) and the effect is the same (it hangs without doing anything on the bus). I believe something is wrong with the PIC configuration.
The logic analyser shows no activity on the physical I2C bus so it looks that actual PIC hardware is not properly initialised.
I hope it is not a big issue for you to fix this as it is stopping me to continue to work.
I'm running on 18LF67K40 internal 64MHz clock and so far ADC and UART are working with this PIC and FC8.2 ok.
Igor
Igor
