Interrupt handler in component
mnf
Has thanked: 70 times
Been thanked: 440 times
Post by mnf »
A bug in 8.2
I tried to create a component that uses an interrupt handler. Unfortunately the name mangling used doesn't seem to apply to the macro called in the enable interrupt icon.
A simple example:
bug.fcfx
(7.48 KiB) Downloaded 216 times
Which creates a simple component with an Init macro.
int_bug.fcpx
(1.03 KiB) Downloaded 227 times
A program that attempts to use this:
bug_demo.fcfx
(6.17 KiB) Downloaded 231 times
The C generated for the interrupt handler:
void FCD_0ff51_int_bug1__interrupt_handler()
    //Local variable definitions
    MX_UINT8 FCL_N;
    // .n = 1
    FCL_N = 1;
& the interrupt setup using the wrong name is:
    ISR(USART0_RX_vect)
        FCM_interrupt_handler();
Which gives compilation errors :-(
Is there a way around this - force FC to use a particular name etc ??
Re: Interrupt handler in component
Hi Martin,
Yes there is an event macro to allow you to add interrupt code inside a component. I'll send you a PM with an example.
