Wlan esp8266 (update) problem
Has thanked: 182 times
Been thanked: 179 times
Today my program gives a lot of strange errors. It shows error in disabled icons..
So I was not sure if the update from the ESP8266 made problem, I go back to the older version, but the same.
Still errors. I delete all program code from the ESP8266, still errors.
I deleted the component from the program and my program was working again. So I put the component back and the errors was back again.
Re: Wlan esp8266 (update) problem
Hi Stefan,
Can you attach the program that is creating the errors and also paste the output of the compiler messages window so we can see the generated errors.
All compiling ok here for me with a very basic program.
After the update the Wlan lost the pin propertis.
it was in a "bad mode". So I put the right pin (Channel 3) to the component again.
It's working again.
Then I let FC8 made the update and it was again in a "bad mode".
and I put the right pin again…
It's working nice now.
After the update bad mode...
Change to the correct parameter
