PIC16F1788 and RA6 as I/O
Frank607
Has thanked: 29 times
Been thanked: 15 times
Post by Frank607 »
I have a PIC16F1788 and I have some problems with port RA6 as an I/O port.
I have 8 switches on POARTA they are all working except on RA6. Also when I connect pin RA6 directly to 5V I get no reaction from this pin.
I have made a simple LED flasher to test these port. (see attachment) RA5 is working and RA6 not.
Is there something in the config of this chip what I must change? Or is there something wrong with the .fcd file?
Simple LED Flasher for testing.fcfx
(11.1 KiB) Downloaded 202 times
Has thanked: 187 times
Been thanked: 205 times
Re: PIC16F1788 and RA6 as I/O
Looking at your program and configuration I see that you have Clock Out = Enabled.
This will output a clock on Port RA6. Try Disabling this in config.
Hope this helps
Frank607
Post by Frank607 »
Hi chipfryer27,
Yes this was the problem. Again something learned :-)
Many thanks for this quick answer.
I've done many such things and most times "I can't see the wood for the trees" :)
Glad it's working.
