Compiler error with Leonardo
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
I'm trying to use an Arduino Leonardo to send data over the USB.
Unfortunately I get some error messages:
D:\PR6751~1\Arduino\Leonardo>"C:\PROGRA~2\Flowcode\Common\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega32u4 -Os -ffunction-sections -fdata-sections -funsigned-char -o "D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.elf" "D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c" -lm -Wl,-gc-sections
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:382:20: error: config.h: No such file or directory
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:384:33: error: lib_mcu/usb/usb_drv.h: No such file or directory
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:386:59: error: modules\usb\device_chap9\usb_standard_request.h: No such file or directory
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:388:34: error: usb_specific_request.h: No such file or directory
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:390:26: error: uart_usb_lib.h: No such file or directory
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:394: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'rx_counter'
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:396: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'tx_counter'
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:400: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'line_coding'
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:402: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'line_status'
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:404: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'serial_state'
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c: In function 'FCD_056e1_USB_Serial1__SendByte':
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:947: error: 'TX_EP' undeclared (first use in this function)
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:947: error: (Each undeclared identifier is reported only once
D:\PR6751~1\Arduino\Leonardo\FlowcodeTest_USB.c:947: error: for each function it appears in.)
Can someone help me?
FlowcodeTest_USB.fcfx
(7.8 KiB) Downloaded 192 times
Re: Compiler error with Leonardo
Please see this topic for more info..
viewtopic.php?f=76&t=21420
Pascal_2016
Hello Benj,
I've made all the recommended changes. I was also able to fix the compiler errors. Unfortunately the USB Serial does not send any data. The USB interface is recognized but no data is sent.
In my test program I built in a delay of 5s at the very beginning.
