Felermeldung 18F25J50 and USB
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
I'm trying to send data over a USB connection.
The microcontroller is an 18F25J50
The settings are without quartz 48MHz
in an endless loop I send data via a USB serial connection to the PC
When I compile the program I get the following error message:
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat 18F26J50 "D:\PR6751~1\" "Flowcode12"
D:\PR6751~1>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F26J50 "Flowcode12.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
(100) unterminated #if[n][def] block from line 904
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat Hat den Fehlercode 1 gemeldet
Autoclose turned off
BEENDET
Flowcode12.fcfx
(9.53 KiB) Downloaded 172 times
Re: Felermeldung 18F25J50 and USB
Thanks for letting us know. I believe I have fixed this problem now and pushed it to the update system.
Let me know how you get on.
Pascal_2016
Hello Benj,
Thank you very much for your quick help. With the new update the USB interface works again.
