Latest version 8.0.2.13
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi team!
I see that some of the colleagues here have a version 8.2.0.13 and if I download some of the team´s examble I get the message "this is made in a newer version". Has it been announced somewhere with the newer version and is there a patch somewhere, Please and thank´s in advance
Br Jorgen
Re: Latest version 8.0.2.13
Hi Jorgen,
What I did was went to the downloads page
Downloaded By selecting the large download button.
Uninstalled Flowcode 8.2.0.12, then installed the newly downloaded exe file.
I could be wrong but I don't think the patch will work with 8.2.0.12?
If that is the case then its odd that is still there?
Post by jgu1 »
Hi Martin!
Thank you for info. Well, normally there are a patch. I hope MM team come up with info :wink:
Br Jorgen
Has thanked: 187 times
Been thanked: 205 times
I can confirm the patch does nothing if you already have 8.2.0.12 already.
I haven't yet downloaded latest version but probably will this weekend as per how Martin did it.
Post by jgu1 »
Hi again!
Dare to ask again before I do something. :wink:
So, is it the way to update to ver.13.
Uninstall ver.12 Download ver. 13 and install? No path somewhere and is all bugs fixed in ver. 13. Please.
Br Jorgen
astro1234
Has thanked: 39 times
Been thanked: 13 times
Post by astro1234 »
Downloaded the patch,after installing showing 8.02.12,so removed flowcode,
then downloaded the full install,now showing 8.2.13, seems to be ok.
Regards Roy.
Post by jgu1 »
Hi Roy and Martin!
Thank you for answer and your patience, maybe I am not clear enough :wink:
I know how to uninstall and install the newer version, but what I would like to know is .13 working as it should? I have seen some have had problems?
At the same time, I would like to know, has it been announced anywhere?
It is by chance I see there is a new version. It would be nice if MM would announce it so we know. Please. :D
I will not annoy you anymore. Thank´s in advance.
*****Edit**** Downloaded .13 and install, work fine. But still nice to know when a newer version is out. :lol: :lol:
Br Jorgen
Glad it's working correctly for you. The update I believe was a minor improvement to fix a bug relating to Hardware OpenGL support on very specific machines. We did not announce it as for most customers it won't really make any difference. :D
Post by jgu1 »
Hi Ben!
Ok, thank´s for info.
Br Jorgen
