16F1937 8bit timer 2/4 & 6
As timer 2/4 & 6 are 8 bits, they should not default to(or allow) 256 rollover value:
When OK is clicked on the values are excepted.Martin
Re: 16F1937 8bit timer 2/4 & 6
Hi Martin,
The rollover of 256 as the default is correct.
The interrupt occurs when the count register goes from 255 to 0 e.g. the 256th count.
0 to 1 = count 1
1 to 2 = count 2
254 to 255 = count 255
255 to 0 = count 256
We use the rollover value - 1 behind the scenes in the rollover register so 256 would become 255 for say the PR2 register.
0 to 1 = count 1
1 to 2 = count 2
Hi Ben,
Thank you, that would explain it
Ah I did not know that.Benj wrote:We use the rollover value - 1 behind the scenes in the rollover register so 256 would become 255 for say the PR2 register.
