Initializing an array
DrElmer
Has thanked: 17 times
Post by DrElmer »
Is it possible to initialize an array when it is declared or do the values have to be loaded later (i.e. in a calculation block)?
Alkaline
Has thanked: 42 times
Been thanked: 41 times
Re: Initializing an array
Post by Alkaline »
You can initialize the array using a calculation icon, otherwise I suggest you use a lookup table where you can enter values ​​directly from the configuration panel
DrElmer
Post by DrElmer »
That is what I have been using as a work-around, but what I wanted to do was to initialize the array with initial values (the same as non-array variables). The Flowcode new variable dialog box appears to support this but I can’t get it to take initial values.
Has thanked: 182 times
Been thanked: 179 times
Several times I had to set a large array by hand. The longest had 800 lines for pixel of a display. I wrote that with an editor and then inserted (copied) in the calculation. Then I took away with the right mouse button "annotations show". And my FC8 program was again well arranged.
(12.08 KiB) Downloaded 635 times
(4.19 KiB) Downloaded 635 times
