Initializing an array
Posted: Wed Sep 04, 2019 1:52 pm
by DrElmer
Is it possible to initialize an array when it is declared or do the values have to be loaded later (i.e. in a calculation block)?
Re: Initializing an array
Posted: Wed Sep 04, 2019 2:21 pm
by Alkaline
You can initialize the array using a calculation icon, otherwise I suggest you use a lookup table where you can enter values ​​directly from the configuration panel
Posted: Wed Sep 04, 2019 3:03 pm
by DrElmer
That is what I have been using as a work-around, but what I wanted to do was to initialize the array with initial values (the same as non-array variables). The Flowcode new variable dialog box appears to support this but I can’t get it to take initial values.
Posted: Thu Sep 05, 2019 5:03 pm
by stefan.erni
Several times I had to set a large array by hand. The longest had 800 lines for pixel of a display. I wrote that with an editor and then inserted (copied) in the calculation. Then I took away with the right mouse button "annotations show". And my FC8 program was again well arranged.
(12.08 KiB) Downloaded 635 times
(4.19 KiB) Downloaded 635 times
