TCP IP Examples (W5500)
- celebriums
- Has thanked: 71 times
- Been thanked: 33 times
Dear Leigh and Benj
Dear Matrix Multimedia Family
Istanbul Turkey warm greetings from everyone.
I stopped dealing with ENC28J60 and
Today I bought the W5500 TCP IP product card.
But I looked for an example on the Matrix Wiki about the W5500,
But I couldn't find it.
I searched the forum on this subject but still could not find an example.
Can you share a sample program for the W5500?
I would appreciate if there is an instance that receives automatic IP on DHCP.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: TCP IP Examples (W5500)
Greetings Sadık!
I have attached a Webserver example using the W5500
However, this does not support DHCP either.
I would have thought that for a server you would want a static IP anyway, and not use DHCP?
But if it is essential, his document might help you to use ARP and UDP to implement your own DHCP request ...
https://www.matrixtsl.com/resources/fil ... ternet.pdf
For this you would need to use the W5500 TCPIP component, not the Webserver component.
- Webserver2.fcfx
- (21.66 KiB) Downloaded 367 times
- celebriums
Dear Leigh
I hope you are fine.
Thank you for helps.
Sample code is very fine working.
I want to ask one more question?
The string expression in the while main loop, (for Example:STRA[20])
How do I show my web server in HTML page 1?
HTML page1 codes:
HTML page1 codes:
<body bgcolor="#33FFFF">
<center><p><h1>Sensor1</h1></p>
<br/>Test Data<br/>
<h1><hr> <a href=\"http://www.sadiksume.com\">www.sadiksume.com<a></h1>
- celebriums
Dear Leigh
Thank you for your quick support. The codes work fine.
Now what I'm going to do is:
Add the TCP / IP Component and send this string data to the port that is open at a destination address such as 192.168.1.8:85
I am work for reading to the incoming codes, via the same port.
Can I do this by adding the TCP IP (W5500) component?
I've been working on the W5500 support for the network comms component today and though I've fixed a number of problems it's still not working 100% nicely for me. I've pushed the various changes to the update system so you can see if it's any better for you now.
Here's my project file. I'll try and get back on this next week.
- celebriums
Hello Ben
Thanks your replies, I hope your are fine..
I tried the code you sent me.
I did the following but couldn't run it.
When I scan only in the IP Scanner,
I can see that the W5500 Ethernet module can receive IP.
Creations:
I made the following changes through your program.
I replaced 18F877 with 18F25K22.
I made the configuration settings.
I replaced 2x16 LCD with 4x16 LCd.
I replaced the C code for OSC settings.
I have set my IP address to 192.168.1.25
Everything works normally on the LCD.
OSC settings are normal, I checked.
However, I didn't see any pages at 192.168.1.25
Creations:
- W5500_2019_0917_New_Webserver_Try.fcfx
- (19.56 KiB) Downloaded 298 times
Hi Sdaik,
Sorry yes the Network comms component isn't quite working with the W5500 yet. Better to use Leigh's example for now as that is known to work well.
I replied to the wrong topic
Currently trying to get the Network comms working with the W5500 so hopefully in the near future this will work ok.
- celebriums
Dear Ben
Thank you for the quick reply.
Sometimes such errors can happen, it's not a problem.
The W5500 works well with the WEB Server component. Leigh's example is seamless.
A temporary period; The TCP IP W5500 component does not work alone.
Did I get right?
Because I am currently doing software for the TCP IP W5500 component. I need to know that.
Did I get right?
- celebriums
Dear Ben
The W5500 works well with the WEB Server component. Leigh's example is perfect.
Did I get right?
Did I get right?
- celebriums
Re: TCP IP Examples (W5500) AUTO IP
Dear Ben, Leigh and Matrixmultimedia Family
Warm greetings from Istanbul Turkey
https://www.matrixtsl.com/wiki/index.ph ... etworking)
Thank you very much for your example NetworkComms W5500 Client.fcfx.
I organized this program for myself. I ran the code. I have successfully run code.
I can move on to the next stage.
Help Request:
The W5500 should be able to receive IP automatically from the Modem.
Can you help me figure out how to do this? I will continue to work on this.
Error 1
On the Flowcode Wiki, it says ESP8266 instead of W5500.
There's a typo.
My Sample Software is attached.
Help Request:
Error 1
There's a typo.
