STM32!
- Has thanked: 1135 times
- Been thanked: 299 times
STM32!
Hi all!
Does FC8 support the STM32 or a similar. I see that it is a powerfull device. https://www.banggood.com/STM32F103C8T6- ... ntent=3216
I have seach in the drop down list but can´t find it, maybe under another name.
Thank´s in advance
Br Jorgen
Thank´s in advance
Br Jorgen
Re: STM32!
Hello Leigh!
Thank’. Do I need to buy the chippack for Arm for these devises or can I ude the Arduinopack?
Br Jorgen
Br Jorgen
Re: STM32!
Hi again Ligh!
I want to buy the ARM chippack, but when I look at my licence I see acroos over the ARM. If I click on ti I see "buy" I click, but no link.
How to buy these chips please? and the programmingway for this device, is this via USB?
STMicroelectronics STM32 Nucleo-64 MCU
Br Jorgen
Br Jorgen
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: STM32!
Hi Jorgen,
Yes the Nucleo boards can be programmed via USB.
Just check that you get one that is on our supported list.
I will ask someone else to comment on the ARM pack purchase.
Leigh
Leigh
Re: STM32!
Ok, Nice. No I don’t have the ARM chippack I have checked. So please a guide to buy it can’t see anyhvere in your website to buy. Thank’s Leigh
Br Jorgen
Br Jorgen
Re: STM32!
Hi Jorgen,
Use the Add To License button here to add bits to your Flowcode license.
https://www.matrixtsl.com/flowcode/buy/
Re: STM32!
Hi Ben!
Thank you. I have just bougth the ARM chip. I try to activate my license again and restart FC8. But I still have a red X on arm chippack.
Do I have to wait or is there another thing I have to do?
One more thing I need a receipt. Are you able to send one to the email I wrote when I order, please.
Br Jorgen
Br Jorgen
Re: STM32!
Hi again!
It´s ok now the ARM pack is activated
But please, I still need a receipt. Will you please ask someone in Matrix to send it to the email I used when I order the chippack.
Look forward to test Arm.
Thank´s in advance.
Jorgen
Thank´s in advance.
Jorgen
Re: STM32!
Hi Jorgen.
I've forwarded your request to the sales team and hopefully they will forward you the receipt tomorrow.
Re: STM32!
Hi Ben!
Just received my STM32F0308Discovery board. I made a simple test. But I am not able to program the board. It seem to compile, but when it have to progamming, I get ERROR code 1
I have installed the toolchain STARM and the ARM. When I connect the board to the USB, the PC see the USB.
Is there anything I forgot to do Please?
Br Jorgen
Br Jorgen
- STM32F0308 Discovery.msg.txt
- (55.66 KiB) Downloaded 208 times
- STM32F0308 Discovery.fcfx
- (6.34 KiB) Downloaded 199 times
Re: STM32!
Hi Jorgen,
Does a drive appear in your My Computer folder when you connect the board? If so then what's the name of the drive?
Re: STM32!
Hi again Ben!
It is recognized but with a question mark. When I open the path there is no driver for this, so, again please advice
Translated : There is no compatible driver for this unit.
Driver for this unit is not installed.
If I try to update driver, it says: no driver for this unit.
Br Jorgen
Br Jorgen
- LeighM
Re: STM32!
Hi Jorgen,
Looks like the USB driver has not installed, could you try downloading and installing the latest ST-LINK USB driver from here ...
https://www.st.com/en/development-tools ... nk009.html
Also, could you please check that you have ST-LINK_CLI.exe in your directory …
C:\Program Files (x86)\Flowcode\Common\Compilers\starm\ST-LINK Utility
Thanks,
Leigh
Thanks,
Leigh
Re: STM32!
Hi Leigh!
Yes I have the ST-LINK_CLI.exe in the directory.
I try to download the driver via your link, but this is not possible.
I follow your link, add my name and email. I receive an email, verifying, click on this, extrem slowly website, then I click on download, after looong time I get the message; "Start over" and have to start from start again. Sometime I get the message stop cause "long script. Sorry. I accept cookie´s. They want me to accept before downloadning.
In a try to find the driver somewhere else, I google it and see this is an issue for many.....
Is there another way to get the driver.
Br Jorgen
Br Jorgen
Re: STM32!
Hello all!
Meanwhile I managed to download the driver. Later this afternoon when I have install the driver, you hear.
Br Jorgen
Br Jorgen
Re: STM32!
Hi Leigh!
I install the driver, and now I can see the device usb. But still not able to program the device.
Please look in att.
Br Jorgen
Please look in att.
Br Jorgen
- (11.92 KiB) Downloaded 2387 times
- STM.msg.txt
- (7.04 KiB) Downloaded 142 times
- STM.fcfx
- (6.34 KiB) Downloaded 167 times
- LeighM
Re: STM32!
That looks like another instance of the Windows short path problem, regarding which there have been a few posts on this forum.
(I think that fix involves changing a setting in Windows and then re-installing the ST ARM toolchain)
I will also have a look at the ST ARM compiler/programmer settings to see if we can get round this problem.
Re: STM32!
Hi Leigh!
Well, ok Leigh. When I ask you, before I bought the chippack and the device, I though you have tested it and knew it was working
Hopefully you are able to fix it. Otherwise I lost money for the ARM chippack
Look forward to hear from you.
Thank´s in advance.
Br Jorgen.
Thank´s in advance.
Br Jorgen.
Re: STM32!
Hi Leigh!
I have 3 Labtop. On all machine I use Win10. The one of them is a newer one and a 64bit.
To be sure, I have installed the driver on all machine, But same issue on all.
Strange If it work for you?
Br Jorgen
Br Jorgen
- LeighM
Re: STM32!
OK, thanks for the update.
I'm running on Windows 7, but we do have Windows 10 machines too.
I'm sure the issue is to do with short paths on Windows 10, which some of my colleagues know more about.
(I personally prefer Penguins to Windows
Windows cannot find the path to the STLink programmer
I am also looking into the possibility of changing the programmer settings to try and avoid the issue
- LeighM
Re: STM32!
Hi Jorgen,
Could you please try updating to the attached file.
This to go into the compiler directory, normally at ...
C:\Program Files (x86)\Flowcode\Common\Compilers\starm\batch
You might need admin privileges.
Leigh
Leigh
- stm32prog.bat
- (419 Bytes) Downloaded 168 times
