OZ2ZTMonie
Posts: 10 Joined: Sun Oct 13, 2019 8:38 am
Been thanked: 1 time
Post
by OZ2ZTMonie » Sun Oct 13, 2019 11:15 am
Hi everyone
Eblocks2 BL0106 Click Board in connection with GPS Click (3.3V)
https://www.mikroe.com/gps-click
User:dsPIC BL0032
How to set Eblocks2 BL0106 Click Board to 3.3v out for the device GPS click
How should the Codes in FlowCode be written?
Like a code example!
Is it something you want to help with?
Mikroe GPS click Code
Code snippet
1 void parse_gps( int *lat, int *lon )
2 {
3 char *string = strstr(txt,"$GPGLL");
4 if( string != 0 ) {
5 if( string[7] != ',' ) {
6 *lat = ( string[7] - 48 )*10 + ( string[8] - 48 );
7*lon = ( string[19] - 48 )*100 + ( string[20] - 48 )*10 + ( string[21] - 48 );
8
9 if( string[17] == 'S' )
10 *lat = 0 - latitude;
11 if(string[31] == 'W')
12 *lon = 0 - longitude;
13 }
14 }
15 }
Like a simple FlowCode example
Posts: 15312 Joined: Mon Oct 16, 2006 10:48 am
Has thanked: 4803 times
Been thanked: 4314 times
Post
by Benj » Mon Oct 14, 2019 10:09 am
The BL0032 board will automatically run the IO at 3V3.
As for interfacing the module you can either use the GPS component which should work well or you can instead use the UART component if you want to parse and decode the GPS NMEA message data yourself.
Example available here.
https://www.matrixtsl.com/wiki/index.ph ... (Wireless)
OZ2ZTMonie
Post
by OZ2ZTMonie » Tue Oct 15, 2019 4:33 pm
Hi Benj
Uses: Eblocks2 dsPIC BL0032
Can you see why, when the keyboard is pressed, the motor cannot run left or right?
With KeyPad 4 engine Start reverse and at KeyPad 6 engine run Forwards
[img]
[/img]
OZ2ZTMonie
Post
by OZ2ZTMonie » Wed Oct 16, 2019 10:07 am
Hi everyone
Is there anyone here who will help get the keyboard pressed, the Motor can't run left or right?
Post
by Benj » Wed Oct 16, 2019 11:38 am
Are you having the problem with the simulation or the actual hardware?
I have removed your output icons from the switch statement and now when I push and hold the keys 4 or 6 in simulation the motor spins.
OZ2ZTMonie
Post
by OZ2ZTMonie » Wed Oct 16, 2019 2:11 pm
Hi Benj
Regarding: "output icons from the switch statement".
Have tried as the picture illustrates below and also completely removed them, but can only run Run Right.
OZ2ZTMonie
Post
by OZ2ZTMonie » Thu Oct 17, 2019 7:41 pm
Hi everyone
Is there anyone here who can tell me why I can in practice Run Left and Run Right but not simulate in Flowcode?
Is there something I'm doing wrong?
Or a better way to write the codes?
Attached the codes here!
Uses the KetPad 4 keyboard to run the motor in the left direction and KetPad 5 to run the motor in the right direction.
OZ2ZTMonie
Post
by OZ2ZTMonie » Mon Oct 21, 2019 9:08 am
Hi Benj
I can't get Windspeed to work with dsPIC BL0032
For example, user Port F/C F0 Pin 0
Do you have another suggestion?
Interuupt:
Interrupt Freq 50Hz.JPG (13.38 KiB) Viewed 5122 times
Interuupt:
Interrupt Aneometer.JPG (13.6 KiB) Viewed 5122 times
See file below
Hope very much you will help with a solution
Compiler_Messages:
Target folder: C:\Users\sun\Desktop
Source name: C:\Users\sun\Desktop\BL0032_KeyPress-012.fcfx
Title:
Description:
Device: PIC16.33E.BL0032
Generated by: Flowcode v8.2.1.14
Date: Monday, October 21, 2019 11:05:34
Users: 1
Registered to: monie jacobsen
License key: X6U4U7
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat "BL0032_KeyPress-012" "C:\Users\sun\Desktop\" "33EP256MU806"
C:\Users\sun\Desktop>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "BL0032_KeyPress-012".c -o "BL0032_KeyPress-012".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
BL0032_KeyPress-012.c: In function '_T1Interrupt':
coff-cc1.exe: warning: _T1Interrupt PSV model not specified for '_T1Interrupt';
assuming 'auto_psv' this may affect latency
BL0032_KeyPress-012.c: In function '_T2Interrupt':
coff-cc1.exe: warning: _T2Interrupt PSV model not specified for '_T2Interrupt';
BL0032_KeyPress-012.c: In function '_INT3Interrupt':
coff-cc1.exe: warning: _INT3Interrupt PSV model not specified for '_INT3Interrupt';
BL0032_KeyPress-012.c: In function '_INT4Interrupt':
coff-cc1.exe: warning: _INT4Interrupt PSV model not specified for '_INT4Interrupt';
BL0032_KeyPress-012.c: At top level:
BL0032_KeyPress-012.c:9160:2: warning: '_FGS' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FOSCSEL' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FOSC' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FWDT' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FPOR' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FICD' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FAS' definition has been deprecated: consider migrating to #pragma config
BL0032_KeyPress-012.c:9160:2: warning: '_FUID0' definition has been deprecated: consider migrating to #pragma config
Compilation successful!
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_link.bat "C:\Users\sun\Desktop\BL0032_KeyPress-012" 33EP256MU806 33E
xc16-ld 1.26 (A)
Program Memory [Origin = 0x200, Length = 0x2aa00]
section address length (PC units) length (bytes) (dec)
.text 0x200 0x4ce 0x735 (1845)
.const 0x6ce 0xc4 0x126 (294)
.text 0x792 0x2698 0x39e4 (14820)
.dinit 0x2e2a 0xe 0x15 (21)
Total program memory used (bytes): 0x4254 (16980) 6%
Ivt Memory [Origin = 0x4, Length = 0x1fc]
.ivt._T1Interrupt 0x1a 0x2 0x3 (3)
.ivt._T2Interrupt 0x22 0x2 0x3 (3)
.ivt._INT3Interrupt 0x7e 0x2 0x3 (3)
.ivt._INT4Interrupt 0x80 0x2 0x3 (3)
Auxflash Memory [Origin = 0x7fc000, Length = 0x3ffa]
Total auxflash memory used (bytes): 0 (0) <1%
Data Memory [Origin = 0x1000, Length = 0x7000]
section address alignment gaps total length (dec)
.nbss 0x1000 0 0x44 (68)
.bss 0x1044 0 0x14 (20)
Total data memory used (bytes): 0x58 (88) <1%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x1058 0x6fa8 (28584)
Maximum dynamic memory (bytes): 0x6fa8 (28584)
Generating HEX file
C:\Users\sun\Desktop>xc16-bin2hex -omf=coff "C:\Users\sun\Desktop\BL0032_KeyPress-012".cof
Generating Assembler file
C:\Users\sun\Desktop>xc16-objdump -omf=coff -S "C:\Users\sun\Desktop\BL0032_KeyPress-012".cof 1>"C:\Users\sun\Desktop\BL0032_KeyPress-012".asm
HEX file creation successful!
Launching the programmer...
C:\Program Files (x86)\Flowcode v8\tools\mLoader\mLoader.exe -eb091 "BL0032_KeyPress-012.hex" -config
Loading file...
File loaded from...
=> BL0032_KeyPress-012.hex
File sending...
File sent!
FINISHED
OZ2ZTMonie
Post
by OZ2ZTMonie » Mon Oct 28, 2019 9:30 am
Hi everyone
Does anyone here see why I can't see Satallites which is attached below
Do you have a suggestion in the codes that the Satellite's number can be seen in the display
File attached:
Post
by Benj » Mon Oct 28, 2019 11:11 am
The satellite count record is currently set to no under the GPS component properties. Change this to yes and you should be able to get the sat count.
OZ2ZTMonie
Post
by OZ2ZTMonie » Mon Oct 28, 2019 11:39 am
Hi Benj
Thank you very much.
That was the solution
Have a nice day at work;-)
