WS2812B - Microchip or Atmega ?
I need to control 300 WS2812B LEDs (5 meter) Before I start developing a driver board I need to know which chip I should use for this project.
I have read that the younger Microchip devices such as the PIC16F1509 are fast enough to control 300 WS2812B LEDS. Or should I use an Atmega328 ?
Maybe there are other “better” devices for this project.
- Has thanked: 70 times
- Been thanked: 440 times
Re: WS2812B - Microchip or Atmega ?
I've used an Arduino Uno 328p with success, but bear in mind the limited ram might cause problems with longer strands of LEDs.
I've been trying to get at Attiny85 working- it works beautifully with a 60 led strand using adafruit's strandtest (power from 5v pin on a digistump board) and also Josh's code see https://www.google.com/amp/s/wp.josh.co ... -them/amp/ yesterday I got this to compile ( but not work) as supplementary code. This technique has the advantage that the contents are not buffered in ram so longer strands can be controlled.
