Getting some infor from Mega to me???
secs
Has thanked: 2 times
Been thanked: 12 times
Post by secs »
Hi all.
Its probably a simple answer but...
I am just tinkering with an Arduino Mega 2650 while I wait postage next week. I have it reading an analog pin. I need a simply way of seeing what that value of the pin is? I used to have an old lcd screen laying around but cant find it. I used to use simple rs232 data to see it.
Can I get the mega to send anything to the PC? of am open to suggestions?
Peter
secs
Re: Getting some infor from Mega to me???
Post by secs »
Actually I just found it but not sure how I did. Will have a play and see what I did????
Using a UART component you can send data through the on-board USB2Serial back to the PC. Flowcode can monitor the serial port using the Serial Monitor component and the Console window. Alternatively you could use a terminal emulator or the Arduino IDE software.
LEDs can also be useful ;)
secs
Post by secs »
Thanks all.
Yep thats the solution I stumbled upon but didnt know how I did it. Got it sending data. Also agree with the LED part. In fact I used an Arduino to run my aquaponics system in the back yard and had an LED mounted on the system where I could see it from the kitchen window. The number of flashes was used as the status of the system...
