BL0127 stepper motor
ycc
Post by ycc »
I wrote a n example of stepper motor using Bl0127 board.
The motor always rotate clockwise no matter I use incrementStep or DecrementStep macro.
Is there anything I should notice?
ycc
stepper test.fcfx
(8.6 KiB) Downloaded 204 times
Re: BL0127 stepper motor
Please try altering the order of your pin connections.
Currently you have the connections as this.
Coil 1 = C3
Coil 2 = C4
Coil 3 = C5
Coil 4 = C6
Please change the order to look like this and hopefully this should work as expected.
Coil 1 = C3
Coil 2 = C5
Coil 3 = C4
Coil 4 = C6
ycc
Post by ycc »
Hi Benj,
Changing the step type to half step works OK now. :D
