ENC28J60 TCPIP working nice but LED?
Has thanked: 182 times
Been thanked: 179 times
The ENC28J60 TCPIP is working very nice.
But I suspect that unintentionally pin will be changed. I use PIN F1 on my board for something else and if I connect the lan Cable it gives problems.
I'm not sure what this code does in the ENC28J60 and how can I remove it.
   Use :Turn the LED off.
void FCD_03d99_led_base__TurnOn()
    #if (1)
        // pin = polarity
        SET_PORT_PIN(F, 1, 0);
    // #else
    //Code has been optimised out by the pre-processor
    #endif
   Use :Turn the LED on.
void FCD_03d99_led_base__TurnOff()
    #if (1)
        // pin = 1 - polarity
        SET_PORT_PIN(F, 1, 1 - 0);
    // #else
    #endif
Re: ENC28J60 TCPIP working nice but LED?
Hello Stefan,
I've just looked at the code generated by the ENC28J60 component and there is no LED or LED_base so it looks like it's another component that is generating this code, maybe a LED?
If you can send me the project file, public or private then I'll try and help you track down which component is generating the code.
It's like on the foto.
I used some Olimex part.
Some code are from a samplecode of FC.
There are comment and code I did not use and I can not understad what the code is meaning.
Maybe it's a side-effect.
FC8-Leddriver_prototype1_PicMX_1 -lan.fcfx
(112.93 KiB) Downloaded 185 times
