Strange Configuration Feature
Docara
Has thanked: 28 times
Been thanked: 61 times
Post by Docara »
Working through the datasheet configuring an 16LF1823.
Noticed that FV7 has a function that the datasheet makes no mention of - a 'Voltage Regulator Capacitor' it would be nice to use. Is this a phantom FC 'feature' or a cocked datasheet. What's the story
(13.24 KiB) Downloaded 907 times
Re: Strange Configuration Feature
Thanks for letting us know.
It looks like the 16F19xx devices have this feature but the 16F18xx do not and the bit is marked as reserved in the datasheet. Very odd!
I'll get it removed from the 16F18xx definitions, not sure how it ended up being there in the first place. If you leave the setting as disabled then it should work as if there is no setting there.
