PIC16F1825 IOC Interrupt
DirkB
Has thanked: 7 times
Been thanked: 11 times
Post by DirkB »
the ioc interrupts on the pic16f1825 doesn't works.
I need ioc Interrupts on 5 Pins on port a. Two of the
interrupts must be trigger on both edge. Is this possible?
thanks
Dirk
Re: PIC16F1825 IOC Interrupt
Hi Dirk,
Have you selected the pins and how you would like them triggered?
(42.9 KiB) Downloaded 521 times
If so, are you saying they just don't work?
Do you have either internal weak pull-up, external pull-up or pull-down resistors?
If not I/P's could be floating.
DirkB
Post by DirkB »
Hi Martin,
i have external pull-ups on A0 and A1 for trigger both Edge
using reflex-coupler, pull-downs on A3, A4 and A5 for trigger
with switches on rising egde. Setup is right. A0, A1 green, A3,
A4 and A5 red ;o)
For testing A0 triggers a macro only a LED goes on in a loop.
No interrupt works. ???
Dirk
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
How do you see if the controller is running? do you have a LED that is flashing at a fix rate for example
Can you post your flowchart so we can see if we can spot something?
DirkB
Post by DirkB »
Hello at all,
I have probably found a bug. If you activate several interrupts,
only the last one of the activated interrupts will work. The others
will be deactivated.
Think it is a Job for Ben ;o)
Dirk
Hi Dirk,
This shouldn't be the case, please can you attach a simple program that exhibits this problem and I will investigate for you.
Edit, I see you've created a new topic with an attachment so I've answered here.
viewtopic.php?f=78&t=21731&p=98477#p98477
