console rs232 FC8
console rs232 FC8
How to open the rs232 console for sending and obtaining information? In FC5 at addition of rs232 the console appeared automatically!
Re: console rs232 FC8
Hi sek,
You have to have the Test & Debug feature pack.
If you have then select View, Console.
Default is not to automatically show console.
I have it, but in the console only two tabs "default" and "E-bloks 2 auto id". In them there are no events. how to apply to my rs232?
Oh, I see.
RS232 Console data is disabled by default.
You will need to enable console data within RS232 properties:
Thanks friend! I was helped by your council. Tell how to display messages at line, but not in a column:
00/00/00 - 00:00:00 - Init()
00/00/00 - 00:00:00 - Send( 'H' / 0x48 / 72 )
00/00/00 - 00:00:00 - Send( 'a' / 0x65 / 101 )
00/00/00 - 00:00:00 - Send( 'l' / 0x6c / 108 )
00/00/00 - 00:00:00 - Send( 'o' / 0x6f / 111 )
I have pushed an update to the update system which will allow you to view the data in a simple form using the new Console Format property.
Use the Help -> Check for updates menu to get the latest files.
Let us know how you get on.
