Is Flowcode v8.2.1.1.14 broken with win 10 pro v1909 ?.
Today i upgraded both of my computers to the latest win 10,
now i find that flow code v8 will not run some of my files.
All LCD showing half a screen only,
slider missing top half of the numbers.
Slider will not move when running at normal speed.
All was working OK before the upgrades.
Does flow code need a update, to get things going again ?.
Regards Roy.
Flow code Broken with win10 pro v1909
Re: Flow code Broken with win10 pro v1909
Hello Roy
I also have Flowcode 8.2.1.13 running under Windows 10 Pro Build 1909 and more smoothly than under previous build (1903).
I do not know the described problem after the update to build 1909, but before you reinstall Flowcode, try the note below
viewtopic.php?f=78&t=21531&start=25
Maybe reinitializing Flowcode can fix this problem.
Christina
Christina
Please open Flowcode and load your project. Then click View and Global Options.
In the Application tab change the Graphics engine from OpenGL Software to OpenG Hardware.
The software mode was incorrectly set to be the default for the latest version which has a very limited texture buffer and hence only half the textures are showing.
Thank you Benj,that sorted it out,now all working.
Regards Roy.
Regards Roy.
