EEPROM - built in eeprom in chips..
DCW
Has thanked: 14 times
Been thanked: 10 times
Post by DCW »
Hello folks.. so in Data menu of flowcode 8, is EEPROM, for the internal eeprom of a chip, to which one may store data to..
If you put it into say 2D dashboard... examine the properties, you see some default values.- OKAY..
So then you write a program, to use the WRITE or READ function of EEPROM... OKAY..
WHY does it refuse to work..? The WRITE function .. just does not work..??
The READ function, reads values stored by entering changing the values, in the PROPERTIES of the EEPROM ...???
So what is the MAGIC..?? please.?? what am I doing incorrectly... WHAT have I forgotten.. please..
I ... just believe if the BOFFINS have included this function, then it must work.?? NO..??
So please someone.. can someone please enlighten me, as to what the MAGIC is... in order to write to the inbuilt EEPROM of the chip, using the EEPROM component...?? ... in a flowcode program..??
Spencer..
Re: EEPROM - built in eeprom in chips..
Hi Spencer,
Can you post a flowchart with the EEPROM issue?
DCW
Post by DCW »
Hello Martin ole buddy..!!
Sure... just want to re-create it - after I deleted it..!!!
Shortly... Shortly...
