There is a small confusion in my mind regarding the code/program size after compilation to *.hex in between a program written in Flow Code and any other "C" language software. Does that really make a big difference in memory utilization if compared between FC and other software.
If there is a big difference is it possible to imitate the same thing written in "C" language software using a "C" block (insert C Code) in FC (no doubt I know nothing about "C" language) to allocate/assign one of the ADC pins as analog input and reading that input as GetByte, instead of using the Component Macro.
I hope I was clear to explain my doubt.
Thank you.
Abhi
