PWM Atxmega
slavaag7
Been thanked: 3 times
PWM Atxmega
Post by slavaag7 »
When PWM atxmega32a4 is turned on, a compilation error occurs. How to enable PWM?
ATXMEGA_PWM.fcfx
(7.37 KiB) Downloaded 192 times
(52.47 KiB) Downloaded 787 times
Re: PWM Atxmega
Many thanks for letting us know. I beleive I have now solved the problem and pushed the fix to the update system. Simply use the Help -> Check for updates menu in Flowcode to get the latest files.
slavaag7
Re: PWM Atxmega
Post by slavaag7 »
Yes, compilation works!
I collect in iron, check and write right away.
And the timer 2. 3. 4 can be solved?
Thanks.
P. S sorry for the errors I am writing with the help of a translator.
(36.71 KiB) Downloaded 780 times
Re: PWM Atxmega
Thanks again for letting us know, the timer problem should be fixed for you now too :D
slavaag7
Re: PWM Atxmega
Post by slavaag7 »
Thank you very much.
